Hi guys,
I went to a machine today that was multifeeding from tray 3, with only 1 copy requested, (replaced feeds and torque limiter with the same result) I then swapped the unit to tray 4 and the problem moved to tray 4. It
After looking at the feed unit i stripped and cleaned the pickup solenoid and it worked ok.
My question is: Has anyone else found this cure? as the manual hardly mentions the pickup solenoid.
