mpc 4500 - sc code 443
  • andrewdecruz
    • Jul 2009
    • 74
    hi fellow techs,
    i got a machine mpc 4500 throwing out sc code 443. i tried replacing the whole transfer unit but the problem still shows sc443. Any help is greatly apporeciated...thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mpc 4500 - sc code 443
    Did you replace the unit with a brand new one, part number B223 6034 or one from another machine? Apparently a new transfer unit was released with added "ribs" to stop the PCU's touching the encoder board and causing this SC.
    Also, from Goose Guide:
    SC 443 Image transfer unit error - set transfer unit correctly
    SC 443 Image transfer unit error - check CN223-1 for 5vdc sensor opertion, replace IOB if OK
    SC 443 Image transfer unit error - check for binds in belt rotation
    SC 443 Image transfer unit error - replace transfer unit assembly (bad sensor)
    SC 443 Image transfer unit error - replace ITB unit-TB #28
    Hit it.
    • meldwo
      • Feb 2012
      • 36
      replace the transfer belt motor
      • sandmanmac
        • 3963
        I'm sure after 2 + years he's likely found a solution
        • Zaxxon
          • 608
          You'll never know, perhaps he is thinking "finally"
          Please start you post with brand, model, problem.
          • bob marley
            • Jan 2012
            • 1339
            It could be a defective encoder sensor or defective image transfer unit motor
            Live for yourself and you will live in vain. Live for others, and you will live again
