MP161F
  • Dickie
    • Nov 2011
    • 190
    MP161F
    Is it possible to disable super G3 fax mode thus pegging the modem speed at 14400.
    We have a customer who uses a non wired electrical plug in telephone line extender which works perfectly from old machines with a max modem speed of 14400 but as soon as you go over this speed a com error occurs every time.
    I suspect it is just a soft switch setting but as we do not have the fax manual we are struggling & we have got 3 potential sales riding on being able to do this.
    Thanks in anticipation
  • engineers
    • 51
    Re: MP161F
    You can change the transmission speed using the communication bit switches in service mode to a minimum of 2400bps
    • Jomama46
      • 2900
      Re: MP161F
      HTH
      sigpic
      A+; Network +; PDI+
      • Llama God
        • Mar 2009
        • 1353
        Re: MP161F
        Originally posted by Jomama46
        HTH
        HTH?
        • Jomama46
          • 2900
          Re: MP161F
          Hope this Helps you Limey Igno
          sigpic
          A+; Network +; PDI+
          • Debs1964
            • Oct 2010
            • 1687
            Re: MP161F
            Originally posted by Llama God
            HTH?
            Hope this helps?
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Athlontini
              • Jun 2012
              • 269
              Re: MP161F
              Go to Fax SP 1-105, switch 03, and turn bit 2 off (0). This will step it down to 14.4.
              In case nobody wanted to download the attachment above.
              • Llama God
                • Mar 2009
                • 1353
                Re: MP161F
                Gay...
                • Jomama46
                  • 2900
                  Re: MP161F
                  Originally posted by Debs1964
                  Hope this helps?
                  You got it babe,
                  sigpic
                  A+; Network +; PDI+
                  • Llama God
                    • Mar 2009
                    • 1353
                    Re: MP161F
                    You got it babe,
                    Someone's on the pull. You smooth-talking bugger you!
                    • Jomama46
                      • 2900
                      Re: MP161F
                      maybe
                      sigpic
                      A+; Network +; PDI+
                      • nhatthuc0000
                        • Dec 2007
                        • 44
                        Re: MP161F
                        I
                        hihihihihihihih
                        I know
                        Hope this helps?
                        Good luck to you!
                        • Llama God
                          • Mar 2009
                          • 1353
                          Re: MP161F
                          Originally posted by nhatthuc0000
                          I
                          hihihihihihihih
                          I know
                          • Dickie
                            • Nov 2011
                            • 190
                            Re: MP161F
                            Thanks for all your replies but unfotunately it DNH (Did not help)
                            We assumed, that because our other test machine, an old Brother 1020 was both sending and receiving to/from a Brother 8360P that the problem was speed related and that slowing down the Ricoh would solve the problem.
                            But no, the Ricoh will receive but not send when the line extender is used, regardless of which machine is connected to the line extender. We have also tried using both Brother machines on one end with the Ricoh at the other and still no joy even after slowing down the modems. When both machines are plugged directly into phone lines it works no problem.
                            Does anyone know of any compatability issues or if there are some other settings we can play with in an attempt to get this to work in conjunction with the non wired line extension ?
                            • Jomama46
                              • 2900
                              Re: MP161F
                              NID (no I dont)
                              sigpic
                              A+; Network +; PDI+
