Hello to every1.After reading some posts on this forum i decided to post a problem of my own
The costumer has 2 MPC 3002 ( on diffrent floors) , One of the copiers had the fuser broken ( The fuser was brokenby an user)
Changed the entire unit with a new1 .
The problem is that everytime it starts or recovers from energysave (standby w/e) the pressure roller is turned to much ( makes 5 or 6 complete turns) so it makes a "clink" sound/noise After 5 or 6 "clinks" the copier runs as it should.
Until now i changed : the pressure sensor, fusing unit , firmware upgraded , bicu bord , harness of the pressure sensor.
( i was thinking about downloading the nvram from the working one and to upload it to this , but then i guess the counter will change also wich is a big no no )
Any opinion is most welcomed.
