RICOH PRO 1356
  • PinevskiS
    • Jul 2009
    • 283
    [Error Code] RICOH PRO 1356
    Hi All,
    I have a problem, when printing a copy of all the captivity moves up and down while in SP modem side to side is 0.0 mm.
    Double feed sensor has not been replaced although.
    SC history all 10 eror code 585.
    I turn off the doubje feed sensor 1908 -001 is off, 002 is off and 003 is off.
    Do you have a solution?
    Thanks.20121129162936843.pdf
  • katash
    • May 2010
    • 221
    Re: RICOH PRO 1356
    Originally posted by PinevskiS
    Hi All,
    Thanks.[ATTACH]18420[/ATTACH]
    you cannot turn off the CIS sensors only adjusts them when they are clean,done that?
    • kannuki2
      • Feb 2012
      • 398
      • PinevskiS
        • Jul 2009
        • 283
        Re: RICOH PRO 1356
        Thank you to all the problem is solved.
        Was replaced CIS sensor, both sensors and TRAY 2 was broken and paper was not in position.
        Thanks.
