error sc 120
  • margic brian
    • Jul 2012
    • 97
    [Error Code] error sc 120
    hello to everyone
    this question might have been asked before but i please would like your help, just recently installed scan features on an mp2000 fully(scan to folder) but this the error i get sc120 what could be the problem your help will be highly appreciated
    thanks in advance
  • Eric1968
    • 2458
    Re: error sc 120
    Scanner Home Positioning Error. Could be a defective Home Positioning Sensor.
    • sandmanmac
      • 3981
      Re: error sc 120
      Originally posted by margic brian
      hello to everyone
      May have been asked before? No kidding.
      It's an SC code. You supposedly work on copiers for a living, and you don't even have the capacity to look up a simple SC code?
      At least make an effort. Just try the search function. I did, and found several posts about it
      • JustManuals
        • Jan 2006
        • 9838
        Re: error sc 120
        Paul@justmanuals.com
        • margic brian
          • Jul 2012
          • 97
          Re: error sc 120
          i know you aint kidding but this sc code only appears when i use the scanning option so to me it appears rather tricky and i can only clear it when i switch the machine off and on. and besides its a new copier. thanks
          • Llama God
            • Mar 2009
            • 1353
            Re: error sc 120
            Better speak to Paul...
            • Herostrat
              • Oct 2012
              • 220
              Re: error sc 120
              Paul speaks...like he can say something other than:
              Paul@justmanuals.com???
              • ma3xx
                Re: error sc 120
                Hi, Im new here. I got the same problem as u few days ago. The solution is belt on the lamp is too tight. Loosen it a bit. Remove the scanner glass and at the left most side you can see a screw, just below the ADF glass, on the loop of the belt. Loosen it both side and its solve.
                • margic brian
                  • Jul 2012
                  • 97
                  Re: error sc 120
                  hi man thanks for your advice i used white grease instead to help the scanner move freely other than your method but the fact that you showed me where to touch i highly appreciate
