MP2550 no feed jam 003
  • kannuki2
    • Feb 2012
    • 398
    Hi all, has anyone have a non-feed jam on tray #1 ? I replaced lift motor, spring, whole tray, feed roller but no luck.. It still not feed out of tray#1. Tray 2,3,& 4 are working perfectly. Anyone have this problem before?
  • moonraker
    • 28
    Re: MP2550 no feed jam 003
    Check if the tray 1 size sensor has dislodged. That can cause this issue.
    • sandmanmac
      • 3979
      Very common. Here's a TSB I picked up a while back on this very site.
      Non-Feed Jams.PDF
      • Llama God
        • Mar 2009
        • 1353
        [ATTACH]18453[/ATTACH]
        It's almost like there's a search function that you can use to find such things, isn't it?
        • webhack72
          Sometimes jam 003 is the roller clutch of paper station on the back on the mfp together i replaced 2 roller clutch of relay roller.
          • kannuki2
            • Feb 2012
            • 398
            Thank you all for your effort. It was the sensor.
