dsc424- print of error. urgent
  • tullio
    • Feb 2012
    • 268
    print of problem.la machine has 60,000 stampa.opc new. problem same.
  • kannuki2
    • Feb 2012
    • 398
    Re: dsc424- print of error. urgent
    need drum test patterns. do single shot of black, cyan, magenta, yellow (feed paper in long edge feed). Print out SP printer 1103-2 test pattern. Can you post them when you have it?
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 417
      That looks very much like a bad earth to the PCU unit.
      Check all the earthing plates on the three large screws that secure the PCU into the machine, check continuity with a multimeter from the plates to the machine frame. Check all contacts at the back of the machine to the PCU are ok.
      Also I remember a bulletin about this issue where there is an earthing brush inside the PCU belt near the top that gets contaminated with toner, take the PCU out of the machine, put a sheet of paper between the pcu and brush (A3 size or whatever your local equivalent is) and clean off the brush vaccing up the toner as it falls.
      If this problem has only appeared since you replaced the PCU and you've tried the above steps, the likelihood is that you have a bad PCU.
      Last edited by Ollie1981; 12-01-2012, 10:32 AM. Reason: Added Italian translation from google translate
      • tullio
        • Feb 2012
        • 268
        the old opc, this problem does esisteva.lunedi 'I do these tests. Thank you.
        • Llama God
          • Mar 2009
          • 1353
          Lucky you, a DSc424 doing full colour!
          Check the PM yields in SP7803. The dev units do 60k, the PCU does 120k, the charge does 60k.
          Also, this being an utter dog of a machine, the dev units can leak into each other so check that they haven't.
          Finally, good luck polishing this particular turd!
          • tullio
            • Feb 2012
            • 268
            • Jomama46
              • 2900
              If this happens only when copying and not printing or memory prints, then the solution is to replace the lens unit. Old problem. Arriba Senor.
              sigpic
              A+; Network +; PDI+
