MP5500 - Toner Spilled inside machine
  • kannuki2
    • Feb 2012
    • 398
    Hello All, I have a RICOH AFICIO MP5500 that spilling toner at every 31K copies/print.
    So far, I have replaced new drum, cleaning blade, cleaning brush (only at 31,000) and developer (@45,000). But I have to replace charge corona at 35K exactly due to tons of toner spilled on the grid. Also, I noticed toners were covering the laser shield glass also.
    Any suggestions will be appreciated.
    SMC REPORT showed:
    DEV bias = 538.
    VREF SP2220-1 = 337 , VT Display = 347.
  • Herostrat
    • Oct 2012
    • 220
    Re: MP5500 - Toner Spilled inside machine
    Does cooler facing transfer belt and drum unit rotate,what's condition of drum unit grounding,have you cleaned transfer belt,are the pathways to waste toner bottle open and clear,waste toner bottle full sensor condition?
    Your pictures a bit smudged...I'm guessing it's developing assembly and it's slot in machine,yet it's too smugded.
    Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
    • Debs1964
      • Oct 2010
      • 1693
      I've had similar on a couple of occasions where the dev filter is missing, ensure the filter is there and in good condition. As the toner appears to be going above the dev unit, this would be my guess
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • Eric1968
        • 2458
        Are you using OEM toner?
        • kannuki2
          • Feb 2012
          • 398
          No OEM toner. I asked to see the bottle and the customer showed it was genuine toner bottle.
          • totoro
            • 568
            X2 on this. Also make sure that the front and rear drum seal are in good shape.
            Totoro
            • kannuki2
              • Feb 2012
              • 398
              You guys are fast in responding to my problem. Deb, I did check there is a filter on the dev unit and drum ground is good.
              Let me explained prior to this issue. The first issue is the machine threw SC300, I replaced the charge power pack, problem is solved. Then it had SC220 so i replaced the LD board and polygon mirror motor and fixed it. After the parts replacement toner spill start to happen.
              Current Meter on the machine is 2 millions.
              Thanks again guys.
              • thierry
                • Apr 2012
                • 30
                Yep!! After seeing that the machine has 2 million copies on i would also suggest that you check the fan. Also make sure that all the drum seals are replaced and that your developer unit is in a good shape! After so many copies your doctor blade could also be wearing out.
                The absolute solution would be to replace the drum unit as well as your dev unit but make sure that your fan is working as well!
                Good luck!
                • Imprestik
                  • Aug 2012
                  • 297
                  This leak is from the classification unit on the toner hopper part number (B2473161)
                  But at 2 million copies, I can also bet you your dev unit is cactus also
                  Replace dev unit, new bag of dev, clean and vac toner hopper and replace classification unit, should be all sweet....
                  • fbkhan3
                    • May 2012
                    • 421
                    [ATTACH=CONFIG]18469[/ATTACH][ATTACH=CONFIG]18470[/ATTACH][ATTACH=CONFIG]18469[/ATTACH]
                    SMC REPORT showed:
                    DEV bias = 538.
                    Hi
                    Everything said in earlier posts should take care of you problem indeed, i just wanted to add something,
                    i had the same issue with MP6001 running @ 3 million,average 60k per month, last month had to spend some extra hours to clean the recycling units,new Developer bag,firmware upgrade and it's all well now,80k after treatment and it's clean like never before with super Copy Quality!
                    HTH!
                    • Bantams
                      • Jun 2012
                      • 603
                      Seriously 2M If i were you i would go with new PCU Assembly New Dev Unit Assy and New Toner Supply Assembly eck Id even Throw in a new Fuser Assy and a new Transfer unit.
                      But im not you and would have scrapped the beast 1m copies
                      • kannuki2
                        • Feb 2012
                        • 398
                        yea i've already told the customer multiple times about upgrading to a new one but their answer is always "We don't have the budget to buy a new one". I hope i can put this machine out of its misery and see if they have the budget to buy a new one.
                        • semi
                          • Sep 2008
                          • 195
                          2M-is that all ,I've got 3 all on 9.5 m,none of them has a fuser or pcu-I think one is still on the same dev unit & only 1 feed station change between them all!! It's how you look after them
                          • Herostrat
                            • Oct 2012
                            • 220
                            I have several MP6500 with at or above 4Mil copies done,on maintenance...it's tricky sometimes,but ye ocasionaly u need to clean the guts real good.
                            I mean REAL GOOD!
                            Those machines are made for heavy duty jobs.
                            • Bantams
                              • Jun 2012
                              • 603
                              Oooops my bad I misread it as a MP5000 well usually they do last forever I have a few on 5m but in this case then probably just need to replace the dev unit assembly as its probably started to leak dev everywhere
