traded sub assy with no help feeds to the exit displays this all sensors are in working order. J021 jam code all trays.
mp9000,1350 j021
Re: mp9000,1350 j021
Check Bulletin #29 if above did not workFuser heat pipe sensor lag error - Check fuser drive for binding Heat pipe exit sensor - check replace heat pipe exit sensor Heat pipe exit sensor - replace both one-way bearings on fuser. Heat pipe exit sensor jam - Check magnets for the stripper guide plate Heat pipe exit sensor jam - Lubricate fuser drive and adjust timing belt tension Heat pipe exit sensor jam - Lubricate fuser drive motor coupler.
