the page is print quite white
  • akbareshghi
    • Sep 2010
    • 261
    after I clean my High voltage board and removing PCU and dev and again installing them and after executing 5801 and 400dpi laser beam pitch adjustment
    the printed paper is quite white and no thing printed on the ie counter page
    please help me troubleshooting this problem
    one of my fuse that i checked with ohm meter has failed and my NVram is reseted .
    before executing 5801 all things is good
    My machine is 2035 aficio
    thanks for your replys
    Color printing with lowest cost per page is my love.
  • fbkhan3
    • May 2012
    • 421
    Re: the page is print quite white
    Completely messed up!
    only thing i can think off is you interchanged the C(charge) and B(bias) connectors at High voltage board,re-check please!
    look for machines birth certificate somewhere in the front door,if it isn't there which I'm sure it wont be,get it from another working machine and manually input the non default values!
    if it helps?
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • akbareshghi
        • Sep 2010
        • 261
        thanks your reply. I immediately soldring the burned fuse please help me one solution and correct the problem ie
        please describe that if i mistakenly interchange B and C , is it possible that caused to burn the fuse of board
        thank again.
        this picture is related to this problem
        • Eric1968
          • 2459
          Never, Never, Never execute SP5-801! It will only make things worse. If you replace the NVRAM then you must do SP5-801. In all other cases DON'T DO IT!
          • fbkhan3
            • May 2012
            • 421
            thank again.
            [ATTACH=CONFIG]18518[/ATTACH]
            It won't burn any fuse unless HVB or terminals make any contact with main frame,connecting C and B back to proper terminals on HVB should cure the image problem,but there is a tiny fuse on that board (continuity check with multimeter) if you wanna make sure it isn't blown!
            • kannuki2
              • Feb 2012
              • 398
              what fuse did it blown?
              • TonerMunkeh
                Professional Moron
                • 3873
                Why did you do a memory all clear? What did you think it could POSSIBLY fix? It's not something done as a matter of course, i.e. I've just changed the toner, time for a memory all clear!
                Anyway, you'll have to change that HV board.
                Hit it.
