Ricoh-M171 Scan to Email "Specified destination not Programmed error"
  • DDixon
    [Error Code] Ricoh-M171 Scan to Email "Specified destination not Programmed error"
    Getting the following error message when trying to bring up LDAP search on Aficio MP-171 Device.
    LDAP settings appear correct, and connection test within configuration is successful.
    Any suggestions for fix for users that may have had this issue would be appreciated
  • Choro1dal
    • Jun 2008
    • 176
    Re: Ricoh-M171 Scan to Email "Specified destination not Programmed error"
    I would suggest examining the search base with a utility like Softerra LDAP browser and filtering the results with the email attribute used by the MFD.
    From your description it seems that you have made a succesful connection to an LDAP database but the attribute being searched does not exist in the database. (Typically the attribute is either mail or email)
