MP2550sp
  • logrady2331
    • Feb 2011
    • 301
    MP2550sp
    Hello all,
    Pretty sure I know the answer but would like some expert opinions. I have an MP2550sp that displays an "sd card authentication" error. Error code in sc history is an 866 "illegal data on sd card". It has a vm card (JAVA). I can uninstall the extended features and even completely remove the VM card and still get the sd card authentiation error. I can ping it and print to it but cannot web into it to set up the scan to e-mail/scan to folder. I suspect a bad controller. I know I can't be the only unlucky s.o.b. out there. Anyone seen this? Firmware is current.
  • sandmanmac
    • 3981
    Re: MP2550sp
    Originally posted by logrady2331
    Hello all,
    There's a TSB relating to SC866 that says to update system firmware to version 1.1 or newer
    • logrady2331
      • Feb 2011
      • 301
      Re: MP2550sp
      Done. System 1.20, everything else current. Just did it.
      • kannuki2
        • Feb 2012
        • 398
        Re: MP2550sp
        can you tell me the address when you try to wim into it?
        is it HTTP://ip address?
        • NeoMatrix
          Senior Tech.
          • 3513
          Re: MP2550sp
          Are you using any extended java features like Global scan or PCC ?
          If so, old software versions of Global scan can corrupt the VM card as it does excessive read-write updates to the VM Card.
          Replace the VM card with a new one from Ricoh.
          Make sure you have a working scan-print SD card inserted in the machine.
          I've seen faulty scan-print SD cards cause no-connection errors on the network.
          HTH
          • kannuki2
            • Feb 2012
            • 398
            Re: MP2550sp
            I think he has two separate issue here. It's probably an incorrect java sd card is on the machine and he has ssl permit to ciphertext on therefore he can print and ping the machine but he cannot log into the web image monitor when using HTTP://.
            you must change it to HTTPS://whatever the ip of the machine.
            • NeoMatrix
              Senior Tech.
              • 3513
              Re: MP2550sp
              He could try the following , I'm not sure about the MP2550 :
              cmd <enter>
              telnet "ip address " <enter>
              set http up
              logout <enter>
              yes <enter>
              • slot
                • 341
                Re: MP2550sp
                try going into sp mode and run ncs reset its in sp5 somthing cant remember sp
                this will reset you nic and scanner settings i have had this on mpc2500 its todo with the chiptext settings
                also check that sp5985 nic setting is not set to 2
                • logrady2331
                  • Feb 2011
                  • 301
                  Re: MP2550sp
                  Bad controller. Replaced it and it works now. Thanks all!
