SC670-00 on a MPC5502
  • Imprestik
    • Aug 2012
    • 296
    Hey all,
    I have a MPC5502 in the field which I am getting a SC670-00
    Now I replaced the BCU first with no success
    I then replaced the controller with no success
    The only thing left I think to do is the IPU as the code relates to a communication error between the BCU and controller, and the IPU sits between them.
    Has anyone had this before
  • sakura
    • 132
    Re: SC670-00 on a MPC5502
    Originally posted by Imprestik
    Hey all,
    By the book it is
    Engine start up error
    The BCU fails to respond within the prescribed time when the machine is turned on.
    Connections between BCU and controller board are loose, disconnected, or damaged.
    1. Replace the BCU
    2. Replace the controller board
    but from my experience it sounds like a HDD failure. Very common on new models. Have you tried to disconnect HDD and see what happens after? Check it out at least and if it doesn't give you a trouble then replace HDD. I would bet $10 it's HDD ))
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      The manual says everything is a BCU problem; however, it usually isn't. Double check all connections are seated properly by reseating them.
      • thierry
        • Apr 2012
        • 30
        Hey all,
        I agree with Sakura. Have a look at the HDD. You will be surprised! Disconnect HDD and switch machine on. If code is gone then its definetly HDD.
        • Imprestik
          • Aug 2012
          • 296
          I should have mentioned the HDD was the first thing I disconnected
          It did not resolve anything
          • sakura
            • 132
            If HDD, BICU etc didn't resolve an issue than check out all harnesses and cables. Could be a pinched cable. The worst problem possible - guess, guess, guess...
            • kannuki2
              • Feb 2012
              • 398
              I wonder if the EEPROM is bent after replacing the controller or he missed one eeprom ... I did that before...
              • kannuki2
                • Feb 2012
                • 398
                Normally a pinched cable will cause a no-power condition or PSU fuse might pop. I think it's probably the EEPROM on the BCU / controller are defective.
                • Imprestik
                  • Aug 2012
                  • 296
                  There is no EEPROM on the controller
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    I most likely am wrong but doesn't the controller have it's own nvram on it?
                    A little board with a cmos battery on it?
                    I've had numerous failures with those recently.
                    • Imprestik
                      • Aug 2012
                      • 296
                      Well, IPU was done today with no success
                      Last 2 things to do
                      NVRAM on controller board first and if that fails
                      EEPROM on BCU
                      Otherwise if those don't fix it, it's out the window you go....
                      • Imprestik
                        • Aug 2012
                        • 296
                        Well after replacing every board in the machine, nothing seemed to fix this issue.
                        Anyway after disconnecting everything 1 by 1 off the device, it ended up being the operation panel taking down the machine
                        • FMC
                          • Aug 2008
                          • 88
                          Can't remember if it's related or not, but does it have an software running on it, ie GlobalScan, PCC. Could be the Java card is corrupt.
                          • Imprestik
                            • Aug 2012
                            • 296
                            Yeah it only has a fiery on it, but that was 1 of the first things a done also, remove the java card cause I know they play up
