Re: Toner black problem Mpc3000
Hey guys,
I solved the problem with the pump. But I do not know how to help. The whole problem is the rubber roller inside the pump (the same as the mechanism of the waste toner 550, 551, 1051, ...) which eventually fainted and metal stirrer can not rotate in the rubber roller, and consequently the shaft with gear and actuator sensor. I found accidentally manufacturer (Made in China), which produces only rubber rollers. Replace them and solve the problem for 5-7 euros.
Cheers
Hey guys,
Cheers
