E 12 Ricoh DX 2430 product code (C 274-92)
  • kader
    Hello
    I get an error E 12 Ricoh DX 2430, I tested both sensors aves Sp 1-31 and 32 both are good but with both engines I have a problem when I activate Sp mode 2-46 and 2-47 the engine is not running same for both engines clamper motor and master eject motor. I would like to please other advice thank you
    I'm sorry I do not speak anglais
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: E 12 Ricoh DX 2430 product code (C 274-92)
    See if the springs( C252 3556 Spring:Pressure:Master Ejection:13.98N)is still attached on both sides of the pressure plate.
    Nobody is perfect..
