mpc 4500 black line
  • neocozhu
    • Mar 2009
    • 72
    mpc 4500 black line
    mpc4500 dirty in the laser unit make the copy a many back line(only black will ,color will not) ,i find one of the glass (a little square glass)dirty
    i clean it ,the copy it fine again 。but it very easy dirty again,so i dont konw why???
    i am not using the original toner,i just add the toner in the bottle。(350g 140 chinese yuan about2.3 usd )
    but i see the laser unit cover is no problem at all ,so i never konw why the little square so easy dirty(every time a black line in the middle of the glass) OMG!
  • rthonpm
    • Aug 2007
    • 2859
    Re: mpc 4500 black line
    Non-OEM toner is never a good thing to try, especially in a colour machine. The savings you may think you're getting will end up being used in your drums, developer, and fuser being used at a much higher rate, not to mention the copy and print quality issues like you're having.
    • rsyarcia
      Hair Straightener Tech
      • 711
      agree! one of our client used this kind of toner then end up replacing the dev't unit and fusing rollers.
      Nobody is perfect..
      • gaudin
        • Mar 2008
        • 39
        maybe a seal on development unit is defective...use oem toner and a new development unit
        Certified for:
        Compita A+ / N+ / S+
        Microsoft MCST / MCA
        • neocozhu
          • Mar 2009
          • 72
          thanks for your suggestion!
          • neocozhu
            • Mar 2009
            • 72
            thanks for you suggestion !
            • neocozhu
              • Mar 2009
              • 72
              thanks for your suggestion !
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                Dirty laser causes white lines, not black lines.
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                • neocozhu
                  • Mar 2009
                  • 72
                  why i clean the glass ,the copy fine again. is it the problem of transfer belt?
                  • Iowatech
                    Not a service manager
                    • 3930
                    Well, where the laser hits the drum, that's where the printed image occurs, so if the laser is blocked by toner on the glass that will result in lack of printed image.
                    Still, you said that is a little glass. If it is about two centimeters square or smaller, that could be the laser synch sensor lens. While I've never seen this before, I suppose if the laser synch sensor lens was dirty that might cause the laser to fire somewhat erratically, causing black lines. The next time you have the laser unit apart, you might want to check for a leak in the laser unit housing near there that lets the toner in, and cover the leak with electrical tape or something.
                    Last edited by Iowatech; 12-13-2012, 04:12 AM. Reason: Earlier version wasn't specific enough
                    • neocozhu
                      • Mar 2009
                      • 72
                      oh! i think just what u said! so you are the answer to my question! the laser synch sensor lens
                      • neocozhu
                        • Mar 2009
                        • 72
                        well i have another question ,i donot think the dirty is toner ,if it toner leak in,there will be little toner in the bottom of the laser synch sensor lens.
                        but in the bottom it is nothing,so confusetion.
                        • kannuki2
                          • Feb 2012
                          • 398
                          change new BLK drum and developer as a set and see if it still leaks.
                          • Zeldaman
                            • Mar 2011
                            • 946
                            • neocozhu
                              • Mar 2009
                              • 72
                              thanks u ! i purchasing a ld unit to tyr first
