mpc4501 single pass feeder jamming
  • vaughn
    • Aug 2025
    [Jamming] mpc4501 single pass feeder jamming
    I have 2 of these machines with the big adf that are intermitantly making fans out of originals. Tried new one ways and sensors and feed unit, torque limmitter and resist tire. help
  • Horologydoc
    • Jun 2011
    • 61
    Re: mpc4501 single pass feeder jamming
    If you could tell us what jam you are getting that would help. Without much information all I can say is have you tried tech bulletin 13 on the D088 series yet?
    • vaughn
      I will get that info and no I didn't see that bulletin. thx
      • vaughn
        I'm getting lots of 65 & 66 jams scanning entrance and registration jams. also customer says it is eating originals.
        • vaughn
          That bulletin 13 is so vague. What does this fix? Maybe i'll call ricoh and ask them when I get a chance.
          • Horologydoc
            • Jun 2011
            • 61
            You said you did sensors. I'm assuming you replaced or cleaned the reg sensor and the scanning entrance sensor. If so how did the felt look that those sensors point at? Try cleaning that up with a can of air and dabbing them with a black Sharpie and see if that helps out. I've also had where the guide mylars in that bend have gotten bent and will catch the paper intermittently. Hope that helps.
            • dmen
              • Dec 2012
              • 6
              I have several MP series SPDFs having intermittent jamming and tearing the originals lead edge. We have replaced all parts mention by the past threads with no success. I need a fix. Thanks
              • Iowatech
                Not a service manager
                • 3930
                If the originals are getting ripped, you've got something stuck in the paper path, like a staple or something, or maybe a mylar has a nick in it. Go look for that. The only other thing that would rip originals would be that the feed belt and separation roller are worn out, and you claim to have changed those already. Good hunting!
