"Preparing an authent. device, please wait" - MP 201
+ More Options
Posts
  • Athlontini
    • Jun 2012
    • 269
    This machine is on its original controller, and I noticed this while replacing the HDD. There's an older thread with this issue, and following the advice there I ordered and replaced the MBU, to no effect. Does the fax board also have to be replaced when you do this?
  • Llama God
    • Mar 2009
    • 1353
    Re: "Preparing an authent. device, please wait" - MP 201
    Has it just started doing this all on its own?
    • Athlontini
      • Jun 2012
      • 269
      Honestly I hadn't noticed; for most of the call I was updating all the firmware. I did get the message to go away though...
      I popped the back cover and switched the jumper cover on the MBU to "off." Then I booted the machine. I turned fax confirmation back on (the parameter setting had gotten erased) and the thing worked fine. How can that be?
