Ricoh 3045 blank prints
  • ash_572
    • Oct 2008
    • 523
    I've checked the dev unit and there is no dev on the mag roller. I then turned the dev unit unit there is dev on the mag roller. This works fine for a few days and the same happens again. Developer has been changed and initialised.
    What can this be and is there any setting I can change to makethe den unit mix more of ton???
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 3045 blank prints
    Are you sure the dev augers are turning? Take the front cap off the dev unit, cheat the front door and try and do some copies. The gears do eventually wear out. Is the earthing strap missing off the back of the mag roller?
    Hit it.
    • ash_572
      • Oct 2008
      • 523
      Yes the dev augers are turning. When I turn the rear dev gear I can see it mixing from the dev entrance. The earthing strap on the mag roller is present. Very strange
      • 41-willys
        • May 2010
        • 36
        check the Mag roller gears are not slipping under load also check the gear shafts are not cracked and moving in the dev unit
        • kannuki2
          • Feb 2012
          • 398
          Order a new development housing unit (it's cheap). I've had similar issue on MP4000 where the development auger shaft turn into a circle instead it should be an oval shape. It is where the development gear lock in position to turn the shaft. It's not the gear problem.
          • nmfaxman
            • 1702
            Wipe off the mag roller.
            Insert DV unit in machine.
            Let machine run and look for patch on drum with right door cheated.
            No patch, no toner.
            If clean mag roller is still blank, you have no drive to the unit.
            Turn DV motor by hand and see if drive gear turns under pressure.
