image problem in mpc 3500
  • diego_akd2009
    • May 2011
    • 79
    [Electrical] image problem in mpc 3500
    Hi, I have a ricoh mpc3500 with the following problem, the client tells me that gave erro after a power failure, to get the machine gave the error sc548 change the fuser and the error was, but to turn it off and gave the sc234 Error, the restart and gave the error sc230, caught the restart and prints as well but I attached the photos, according to the manual it would generate error ipu board, but how electric system was interrupted doubt if it could not be anything else , any ideas? thank you!
    this is a solid pattern cyan....
  • kannuki2
    • Feb 2012
    • 398
    Re: image problem in mpc 3500
    Electrical surge can take out all the boards. I recommend you should order a new IPU and SBU. Although you can do a test on the SBU to see if it's still good.
    SBU Test Mode
    There is an SP code to create a test pattern which can be used as a diagnostic tool to
    troubleshoot problems in the SBU:
    􀂃 SP4907-001 SBU Pattern - Test Pattern
    To print the pattern:
    􀂃 Select the pattern to print.
    􀂃 Touch "Copy Window" then press the Start key twice.
    • Phil the copy guy
      • Sep 2009
      • 36
      Print a counter print out page to rule out optical problem
      • diego_akd2009
        • May 2011
        • 79
        Thanks for your answers finally was laser module, happy holidays!
        • Phil the copy guy
          • Sep 2009
          • 36
          I have s parts machine if I can hhelp my cell. 413.429.6467
          • lawchatkui
            • Aug 2017
            • 79
            Replace LD unit?
            Sent from my Mi 4i using Tapatalk
            • davel
              • Oct 2011
              • 1107
              Originally posted by lawchatkui
              Replace LD unit?
              I think he did 5 years ago.
              • lawchatkui
                • Aug 2017
                • 79
                Agreed
                • Eli60429
                  • Feb 2017
                  • 7
