Ricoh MP6002 SC555 and SC542
  • knarfdnul
    • Apr 2011
    • 27
    [Error Code] Ricoh MP6002 SC555 and SC542
    I allready changed thermistor, thermotats and bracket with the new parts. The error keep coming back. Today I cleaned the end thermistor and strippers for toner. The end thermistor bracket lowered a bit.
    Any ideas?
  • Larryo
    • Jul 2012
    • 18
    Re: Ricoh MP6002 SC555 and SC542
    Try dropping the temp. ten degrees. I've had succes with that in the past.
    • cpierce1984
      Turn off the AOF feature too. this should be somewhere in Admin Tools.
      • watson
        • Sep 2009
        • 64
        Try setting SP3904 to "2"
        • TonerMunkeh
          Professional Moron
          • 3865
          That's a good idea!
          SP3904 - Short Warm Up Mode:
          Controls when corona wire cleaning is done to adjust the length of time that is necessary for
          startup.
          [0 to 2/0/1]
          0: Charge corona wire not cleaned when the machine is turned on.
          Warmup Time: 30 sec. (Short Process Control is done)
          1: Charge corona wire cleaned only when the machine is turned on.
          Warmup Time: 30 sec. + 40 sec. (for cleaning) = 70 sec. (Short Process Control is done)
          2: Normal startup procedure at power on:
          Warmup Time: 240 sec. (Full process control is done)
          • Potential sensor calibrated
          • Drum starts to turn when fusing unit gets to the warmup temperature (not done during
          Short Process Control)
          • Potential sensor readings are used to adjust development bias, grid voltage, laser diode.
          • ID sensor calibrated (not done during Short Process Control)
          • TD sensor calibrated (not done during Short Process Control)
          Hit it.
          • cwilson
            • Jun 2012
            • 50
            i too have had this problem and even changed the temp and everything that has been suggested here. But alas, i would still get that code. i was very flustered and had another tech go out there with me. He suggested i replace the hot roller. went back, replaced the hot roller and WALLA!!! its seems the hot roller was wearing thin and by replacing it, it made everything happy have not been back since and that has been at least 3 months, in tech time that is....
            But I cleaned the scan glass.......
            • Gift
              • Mar 2011
              • 2459
              hi - what is AOF referring to?
              • tcs04
                FORMER Techie
                • 1183
                Auto Off powersave timer
