problem with ricoh mp 4500
  • muthana
    • Nov 2012
    • 23
    hi all
    the problem is this device cannot allow me to chang any thing in (system setting- administrator tools- dublix 2 side )
    whene i do any change the masseg is apper on screen (( you dont have the privileges to use this fuvction)
    please whate is the solve?
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: problem with ricoh mp 4500
    Login as an admin
    Nobody is perfect..
    • muthana
      • Nov 2012
      • 23
      thank you for your anser but there is no any login as admin or super visor
      the logo as admin in secreen are not avilable
      • rsyarcia
        • 711
        enable(on) administrator authentication.
        Nobody is perfect..
        • johnyb
          • Feb 2011
          • 167
          You may need to press user tools then the key symbol to prompt the admin login screen.
          • muthana
            • Nov 2012
            • 23
            whene i do admin (on) in authentication themassege appare on screen
            • rsyarcia
              • 711
              then what is next?
              Nobody is perfect..
              • CANGO
                • Dec 2012
                • 8
                hola.
                Pon tu IP en el navegador. Ejem 192.168.0.xxx y en la parte superior derecha clica en INICIAR SECION
                hello.
                Put your IP in the browser. Eg 192.168.0.xxx and press enter. In the top right click on START secion
                • mrwho
                  Major Asshole!
                  • 4299
                  Be careful with the supervisor login - you could ruin your equipment, leading to board replacement.
                  Consider yourself warned!
                  Mascan42
                  Ibid
