Aficio 2022 network scanning
  • muaazgujjar
    • 67
    [Electrical] Aficio 2022 network scanning
    Happy new year,One of my clients upgraded his personal computer with "win7" plateform and attached it with AFICIO 2022 .He tried to scanbut his scanning software stopped working ( ADOBE ACROBAT WRITER).Already he was using this machine for scanning through winxp.TWAIN installed is 3.46a.Any help in these busy days .regards
  • copyaction
    • Oct 2007
    • 991
    Re: Aficio 2022 network scanning
    Use SMB scan to folder and no other software will be needed.
    • sandmanmac
      • 3981
      No. 2022 WILL NOT scan to win 7 without a firmware update at minimum. Setup FTP, or scan to email, and don't be afraid to search the forum and check out any of the dozens and dozens of threads about this topic
      • rthonpm
        • Aug 2007
        • 2859
        The 2022 doesn't support NTLMv2 so SMB scanning is going to be out of the question. This model also doesn't support 64-bit TWAIN so you're out of luck there. Depending on the Windows 7 version, you may be able to use XP Mode to create a virtual XP machine that you can use to create a share folder, but the VM would need to be running and set to use a public network IP (bridged networking as opposed to the default NAT). I've set this up for a few of my customers with older equipment and it works just fine for most of them. XP Mode is only for Professional, Ultimate and Enterprise and may not be available everywhere worldwide.
