MPC 3500 SC580
  • mikadonovan
    • May 2008
    • 2931
    MPC 3500 SC580
    Hi, All. I have a problematic B222 that blows IH coils on a regular basis. They may last 6 months, or 6 weeks, but they all blow. This will be the 4th one I've replaced in 2 years.
    The front fuser area fan has been replaced, blades not spinning on shaft
    The inverter board cooling fan works fine
    Machine has a different fuser
    Machine has a different IH coil board
    Has anyone run into this problem of constant IH coil failure? I would really like to get this issue resolved. It's a pain to change, and the customer is less than impressed with the machine.
    NEVER ASSUME ANYTHING
  • collme
    Ricoh tech
    • 221
    Re: MPC 3500 SC580
    which front fuser fan did you replace? the large one which gets dusted up or the sirrocco fan which is enclosed and ends up with solidified toner inside it. If the sirrocco fan is not working fully then you will get IH coils blowing as there is not enough cooling. I realise this may be the fan you have changed but it is the main reason for blown IH coils and all i can think of at the moment sorry.
    • kyoceran
      • 100
      Re: MPC 3500 SC580
      ricoh have a RTB out for this, it involves replacing IH, IH inverter pcb, fitting a gaurd over the drum phase control sensor and the 8A fuse on the primary.
      • kannuki2
        • Feb 2012
        • 398
        Re: MPC 3500 SC580
        [Problem]
        SC 580 IH Inverter Zero Cross Frequency Error displays at power on.
        [Cause]
        IH COIL UNIT
        • The IH coil unit has two connectors, Check CN983 a 4 pin connector for continuity across pins 1 to 4, this will confirm the condition of the two thermostats, TS3 and TS4.
        • Check across T1 to T2 for continuity. This will check if the IH coil has an open circuit or not.
        [Action]
        • If either of these two test show an open circuit replace the IH coil unit.
        [Cause]
        IH INVERTER BOARD
        • Check if the fuse has blown. Replace and try after first checking the above checks for the IH Coil Unit. A blown fuse may indicate a wire shorted or an internal short of the Inverter coil unit.
        • On the IH inverter board check the input voltage from the PSU. CN 981 provides the AC input.
        • On the IH inverter board check CN984 pin 1 for +12vdc input voltage from PSU.
        [Action]
        • If either of these input tests fail check or replace the PSU.
        • If the input checks are OK and the IH Coil Unit checks are OK then replace the IH Inverter Board.
        • turbojetboy
          • Aug 2009
          • 279
          Re: MPC 3500 SC580
          I agree with this, seen it before. Multiple blown IH units - all caused by this little fan which the little "bird cage" fan had broken, but the motor ran fine - hence no fan errors. remove the front plastic cover around the door interlock area and have a good close look at this fan - not the easly to get at one behind the little upper cover next to the paper exit unit.
          • mikadonovan
            • May 2008
            • 2931
            Re: MPC 3500 SC580
            I haven't seen the machine since the initial call. We are pulling it today. I'll let you guys know what I find. BTW, why is there a link to a retail site on the word "cooling fan" in my initial post? I sure as hell didn't put it there.
            • mikadonovan
              • May 2008
              • 2931
              Re: MPC 3500 SC580
              I just looked through the tech bulletins. Again. I don't see anything having to do with an IH coil. What number is it?
              • Iowatech
                Not a service manager
                • 3930
                Re: MPC 3500 SC580
                I'm pretty sure I've seen a Lanier version of that tech bulletin. As I've never seen that problem before I'm not sure if it translates correctly though, but I'll look it up tomorrow and let you know what I find then.
                As for the link to the retail site, I just checked, and I can't find it. But I'm still kind of a noob here, and therefore I might not be the sharpest stick on the pile.
                • rthonpm
                  • Aug 2007
                  • 2847
                  Re: MPC 3500 SC580
                  Sounds like you've got a plug-in or other unwanted software that's plugging in links to terms in your browser. Check your Add/Remove Programs list and also try using MalwareBytes Anti-Malware or some other such programme to remove the offending software. Depending on your browser, you may also want to install something like AdBlock to keep such things from showing up in the first place.
                  • Iowatech
                    • 3930
                    Re: MPC 3500 SC580
                    I wasn't able to find the tech bulletin. I have failed, sorry about that. Maybe kyoceran will come back and let us know which one it is.
                    I know I've seen a tech bulletin like that somewhere, though. It just isn't part of any of the Lanier color technical manuals I have starting with the LD435c (which is the Lanier equivalent to the MPC3500) back through the LD238c.
                    • katash
                      • May 2010
                      • 221
                      Re: MPC 3500 SC580
                      correction the mpc3500 is equivalent to lanier isc3535,
                      for me this problem is fixed by replacing the ih inverter or the board and will keep the copier on a ups,
                      hope this helps
                      • sandmanmac
                        • 3973
                        Re: MPC 3500 SC580
                        I had the same Damn thing happening, and it was caused by an 'add on' as rthonpm had suggested, that slipped by me, and I do use "adblock Plus"
                        Mine was called 'zoomex' and it was installed in both Firefox and Chrome.
                        • mikadonovan
                          • May 2008
                          • 2931
                          Re: MPC 3500 SC580
                          This one is called "skimlinks", and I'm still working on getting rid of it. Deleting cookies, and opting out on the Skimlinks site has not resolved the issue.
                          • rthonpm
                            • Aug 2007
                            • 2847
                            Re: MPC 3500 SC580
                            Be sure to blow out your temporary internet files as well. More than likely you'll still need to run MBAM and maybe even a registry cleaner like CC Cleaner to completely get rid of it; I see a good three or four of these a week on the PC support side of the business. Also, make sure any installs of Java and Flash are up to date, or if you need an old version to run something on your PC then disable them from automatically running in your browser.
                            Sorry to hijack the thread here on this. Maybe we need another forum topic for technician PCs!
                            • kyoceran
                              • 100
                              Re: MPC 3500 SC580
                              apologies for the delay folks , the info you require is Ricoh Technical Bulletin for model AP-C2 6th October 2011 RD029075 for 220/240v machines.
                              I hope this moves your fault finding forward, as a company we find this suggestion to be very expensive and have reservations about its effectiveness.
