Ricoh C2550 / Savin C9025 Add Toner displayed when it is a new toner and tried a 2nd
  • patterson70
    • May 2010
    • 599
    Maybe this is a dead clutch? Before I replace it I wanted to ask if there a Toner End Clear in the service mode? I could not find it anywhere. I tried a Forced Toner but when I executed it it said: Failed. A second brand new toner did not solve the problem. I cleaned the chip on the original toner, but I see that the sensor is kind of in a weird spot that reads the toner, I cleaned that also though. On a MP-161 I had this problem and it was not the clutch, all I had to do was perform a Toner End Clear and it was fine. Thank you.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh C2550 / Savin C9025 Add Toner displayed when it is a new toner and tried a
    for what color is having a problem?
    Nobody is perfect..
    • patterson70
      • May 2010
      • 599
      It is the black.
      • Cuthwald
        • Aug 2012
        • 5
        Its the toner pump
        It is more than likey the toner pump the hose can also be clogged the pump comes with a new hose
        • patterson70
          • May 2010
          • 599
          Thank you. The machine will not go into warm-up, it immediately has the red light and the display shows "Add Toner". If the pump is bad does the machine know that before it even cycles through? That is why I thought I might need to go into service mode and perform a toner end clear. BUt as I said, it does not seem to have that setting, even though a MP-161 does.
          • rsyarcia
            • 711
            we faced the same problem with black, we replaced the toner hopper. check the machine, performed sp 3045-1 to off.
            Nobody is perfect..
            • rsyarcia
              • 711
              Re: Its the toner pump
              FYI my friend, this machine(MP C2550) don't have pump and hose for toner supply.
              Nobody is perfect..
              • patterson70
                • May 2010
                • 599
                Many thanks to you! I will replace the hopper and let you know how it went.
                • rsyarcia
                  • 711
                  read the manual when you replace the hopper coz you have to pour a small amount of developer in it. when you want to check if the toner cartridge is turning you can remove the cover of the internal output tray.
                  Nobody is perfect..
                  • Debs1964
                    • Oct 2010
                    • 1693
                    Lower right hand door not fully closed, if it doesn't attempt to load toner when you close front cover then there is another fault, every time I've had it, the door isn't completely closed
                    There are 10 types of people in this world, those who understand binary maths and those who don't
                    • collme
                      Ricoh tech
                      • 221
                      I second this, especially with the machine not even attempting to add toner.
                      • kannuki2
                        • Feb 2012
                        • 398
                        swap the toner sensor and motor out of the yellow into the black to see if that is the case...
                        • patterson70
                          • May 2010
                          • 599
                          Thanks to all for the advice, all were helpful for the next time, especially Debs1964 and collme as indeed it was the door being open. Now, can anyone tell me why they programmed the machine to hide the open door message on the display when it needs to add toner? Argh!
                          • collme
                            Ricoh tech
                            • 221
                            It was Debs who gave the advice, i just backed her up. make sure you give her some rep for it lol
                            • TonerMunkeh
                              Professional Moron
                              • 3865
                              It doesn't actually hide it, it just makes it very difficult to see. The little red door open message will have been showing at the very bottom left of the LCD, but the machine doesn't exactly make it obvious.
                              Hit it.
