New style MP C4500 PCU's
  • mikadonovan
    • May 2008
    • 2931
    With the new style PCU's, can the black unit be modified to use as a color unit like the old style ones?
    NEVER ASSUME ANYTHING
  • Horologydoc
    • Jun 2011
    • 61
    Re: New style MP C4500 PCU's
    If you are referring to the B2242042 the answer is yes. Just have to remove the pin and shave the rear RJ45 like before. I haven't had any issues. Ricoh's official bulletin was that they changed the gap between the pcu and charge roller and the angle of the lube apply blade to lessen charge roller contamination.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Ditto X2 works fine !!!!!!!!!!!!!
      Mystic Crystal Revelations
      • ptrflrs
        Glorified Parts Swapper
        • Dec 2010
        • 192
        definitely working, one thing to note if it hasn't been mentioned is that the front covers on the new units are different and not interchangeable with the old. hopefully the bigger "gap" onthe charge roller will make a difference.
        jesus loves you! (everyone else thinks you're an assh*le)
        street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
        Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
