Working on a mpc2500. It has a 3rd cassette I think is called a paper bank cassette. It holds 2 large stacks of paper and feeds out the right side. When right side is depleted, paper on left side moves to the right. Problem, it will not move to the right when needed and gives a SC503 error. I can manually move the guide to the right and will go back to the left to home position. It will feed paper from the right side. Nothing is broken or out of place. Did try to replace pcb and electromagnetic clutch with no result.
What is causing the guide on left not to move the paper to the right? Can ya'll help me?
