MPC2800 SC141 after work on the fusing unit
  • mrwho
    Major Asshole!
    • 4299
    Any hints? The optics are clean and I disconnected and reconnected all the connectors, to no avail. Before the fusing-related work, all was fine. Now, all of a sudden, I get SC141. The documentation is scarce, beyond the usual "replace boards" and "reconnect all connectors".
    Cheers!
    Mascan42
    Ibid
  • BLADE
    former propeller tester
    • 478
    Re: MPC2800 SC141 after work on the fusing unit
    check mirrors out of pos if they were cleaned, check white plate, relax scanner drive belt
    • mrwho
      Major Asshole!
      • 4299
      Thanks for the tip. Did everything of the above, except relaxing the belt.
      As I've ordered the SBU and BCU boards yesterday, I'll wait until then, but if everything else fails, then I'll remember to check the belt.
      Thanks.
      Mascan42
      Ibid
      • Polarbear
        • Feb 2012
        • 1070
        Hi
        Does the scanner assembly move during startup?
        Press the GREEN button!!
        • mrwho
          Major Asshole!
          • 4299
          Yes, and the light turns on accordingly.
          Originally posted by Polarbear
          Hi
          Mascan42
          Ibid
          • Herostrat
            • Oct 2012
            • 220
            Heh...I made mistake today and powered on machine after cleaning optics with only glass on and no white plate on top...gave me sc 101 ofc
            I recall that some MP 35/45 machines gave me "Functional problem..." when powering them...just because?!?!
            Scanner assembly didn't move and lamp didn't power on,just turn off and on and it's ok.
            My money is on Belt as Blade mentioned.
            • BLADE
              • 478
              my money is on a board, (a big one)
              • tcs04
                FORMER Techie
                • 1183
                I may be way off, but check the upper right door switch. Right next to the fuser drive. Also make sure the thermistors are in good nick, easily bent / snapped which may cause odd faults.
                • kannuki2
                  • Feb 2012
                  • 398
                  1. Black level detection error - Wire harness behind SBU ground plate was pinched
                  2. Black level detection error - check harness connections to SBU
                  3. Black level detection error - replace SBU
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Have you tried swopping the fusing unit with a known working one - just to check?
                    • mrwho
                      Major Asshole!
                      • 4299
                      Problem solved by replacing the SBU.
                      Why it got damaged by repairing the fusing unit, beats the hell out of me.
                      Thanks all for the input!
                      Mascan42
                      Ibid
