Ricoh aficio mp 4500
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Misc] Ricoh aficio mp 4500
    I face problem with photocopier aficio mp 4500 as the image is light.
    I checked the developer its count 60,000 just and also checked the voltage readings found it the same as it must be.
    Ask your help
    Thank you
  • johnyb
    • Feb 2011
    • 167
    Re: Ricoh aficio mp 4500
    Hi
    Take a look at the VSG VSP readings I guess they are not what they should be, if they are not check out the charge connections all the way throught the pcu, you will probally find the one at the rear is giving poor continuity....
    Cheers
    • TonerMunkeh
      Professional Moron
      • 3865
      At 60k you'll probably find the mag roller is coated in toner making the developer fail. You'll probably find lots of SC304's in the SMC printoffs too. Either that or the mylar paddles in the toner hopper have detached, but I'd more likely bet on the dev.
      Hit it.
      • ricoh passion
        clean the optical scanner
        reviza developer status, check the values ​​of VSP, vsg in sp 3103
        is probvable developer need change
        • andy227
          • Jan 2013
          • 219
          Hi guys, new here, good to be amongst you, hope I can contribute with my meagre experience. Re the above problem, I have to second what TonerMunkeh stated. Dev roller probably black instead of silver, if so clean it thouroghly and carefully, and it may go a few K's until needing cleaning again. I believe those models have the same toner problem as the MP4000 series. There may be a revised coated dev roller available as they did for the MP4000 that suffered from the same problem.
          • logrady2331
            • Feb 2011
            • 301
            There are numerous posts on this site regarding this issue. I picked up a tip on here that helps alot: set the mag roller/mylar gap to a thighht .35 and it will run a ton cleaner.
            • logrady2331
              • Feb 2011
              • 301
              *tight* I wish I could type..................................
              • joshuatin
                Cheek pum unit
