Ricoh aficio color 6513 with SC326
  • mkopoiuy
    • Mar 2008
    • 54
    anyone could help what is that SC326 mean.
    copy is coming ok,
    if i try printing then SC326 comes after 2-3 minete.
    please tell me what is SC326 mean.
    mkopoiuy
  • Steve Perks
    • Mar 2008
    • 32
    Detection Conditions:
    - Timing & Condition -
    The main control board
    does not receive the
    FGATE signal from the LD
    control board. This can
    occur after the Start key is
    pressed (the image
    transfer belt makes 3
    revolutions) or at certain
    timing points during the
    copy cycle.
    - FAGTE signal -
    This signal is generated at
    the LD control board after
    the board receives the belt
    mark signal from the main
    control board. This signal
    is used to synchronize
    laser writes for the
    different colors.
    Possible Causes:
    • Belt mark detection error
    • Electrical noise
    • Poor connection of
    connectors
    • Defective LD control
    board
    • Defective Main control
    board
    Troubleshooting Procedure:
    1. Clean the belt mark (located back side of
    the image transfer belt) or replace the belt
    if the belt mark is dirty or has peeled off.
    2. Clean the belt mark detection sensor.
    3. Clean the development units’ bias
    terminals.
    4. Make sure the harness connectors
    (CN605 & NC406) on the LD control
    board and main scanner IPU board are
    properly connected.
    5. Make sure the harness connectors
    (CN604 & CN306) on the LD control
    board and main control board are properly
    connected.
    6. Replace the LD control board.
    7. Replace the main control board.
    [Signal Check]
    • FGATE: CN604-A2 or TP22 on LD control
    board / CN306-A9 on main control board
    • Belt mark: CN220-A12, TP106, or CN212-
    B11 on I/O control board / CN303-B1,
    TP108, or CN306-B2 on main control
    board
    /CN604-B9 or TP31 on LD control board
    If the machine is equipped with the
    controller,
    1. Make sure the connectors (CN606 &
    CN101) on the LD control board and
    controller I/F board are properly installed.
    2. Make sure the controller I/F board is
    properly connected.
    3. Replace the interface board.
    RTB RB023025 also mentions this problem:
    Symptom:
    Following ITB replacement, the rubber positioning seals around the inside edge of the belt
    peel off at approximately 1-2 kD, causing SC326 or SC452.
    Cause:
    An insufficient amount of setting powder is applied to the ITB, causing the belt to catch the
    blade and bend it backwards. The blade then pushes against a different area of the belt
    (one with no roller underneath), causing the belt to bend inward and the positioning seals
    to contact the Grounding Plate. The seals are then peeled off at their “joint” areas.
    Troubleshooting:
    Please be sure to apply a sufficient amount of setting powder to the entire surface of the
    belt at replacement.
    Note: When in doubt, it is better to apply slightly more powder than less.
    Team Leader/Technical Specialist: CMYK Digital Solutions Ltd
    • mkopoiuy
      • Mar 2008
      • 54
      Thank you very much!!!
      [quote=Steve Perks;25657]Detection Conditions:
      terminals.
      Troubleshooting:
      thank you again/
      I think I can do it by myself.
      have a nice day.
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        theres a sensor on the back side of this machine that reads if the belt is stopping in the right position works inside the belt unit accessable from the front of the machine first take out the transfer roller unit and then take out the Image transfer belt check the inside of the belt (clean) the gold plated belt mark. but sense you going to need to do that, vaccum out the hole machine, check Lubricant bars very important no this machine one under drum brush one on the image transfer roller and another in image transfer cleaning unit under the brush. this will be a small PM or a check up. nothing more to add.
