Af2238c - fusing clutch gear
  • amzandu
    • May 2012
    • 13
    Can anyone assist with the part number of the 21Z gear on the fusing clutch of the AF2238C. The fusing clutch does not seem to appear in the catalog. Physical label shows the clutch is AX20-0246.
    Thanks.
  • amzandu
    • May 2012
    • 13
    Re: Af2238c - fusing clutch gear
    From the parts catalog it appears that the fusing clutch is integrated with the K Development drive unit G077-1100. Is anyone able to confirm that the K drive unit assembly comes complete with the fusing clutch and gear?
    • Polarbear
      • Feb 2012
      • 1070
      Hi
      Have you extricated the drive unit? Check the clutch body - chances are there will be an "AX" number on it - sometimes the manuals are screwed up and drawn wrong.
      I have had instances where clutches are grouped under electrical for instance.
      Can you do a output check on the clutch? can you hear it click?
      Press the GREEN button!!
      • amzandu
        • May 2012
        • 13
        Thanks for responding. The clutch is fine, its the gear on its shaft that has snapped into two. The clutch says AX20-0246 and is not listed in the catalog anywhere - but it sits on the K development drive unit. I am trying to establish if the clutch and gear are sold as part of the K drive unit.
        Regards,
        • Bantams
          • Jun 2012
          • 603
          Yes the drive unit comes with the clutch and gear I fitted one a while ago for the same reason.
          • amzandu
            • May 2012
            • 13
            Thank you very much for confirming that mystery.
            Is there anything in particular that would cause that gear to snap? I have checked the fusing unit, its done about 35K and its not showing excessive load. I would hate to replace unit then have that snap as well - $260.00 at PR.
            • Bantams
              • Jun 2012
              • 603
              IIRC The new Drive units are modified not had one break since and that was about 3 years ago.
              • amzandu
                • May 2012
                • 13
                That is very comforting information. Thank you for taking the time to respond.
                Shall I take it that the part number G077-1100 still applies to the new units?
                • kuby
                  • Oct 2007
                  • 1396
                  How long did it take to replace the part? It is buried under a lot of other stuff. I have one that has the same part broken I just got the call today.
                  • amzandu
                    • May 2012
                    • 13
                    It is quiet a task, about an hour and a half as it was my first time stripping it down this far. Just follow the manual instructions and should be good.
