MP C3500
  • signguys
    • Aug 2025
    [Misc] MP C3500
    Hello All. I'm not a tech on these machines, but figure I would ask those of you that are.
    Ricoh MP C3500 - When you print the margin is off to one side on the long side of the paper. Is there a quick fix for this or what do I need to do.?
    Thanks In Advance
    Michael
  • JustManuals
    • Jan 2006
    • 9838
    Re: MP C3500
    Paul@justmanuals.com
    • signguys
      Re: MP C3500
      I have Them, Just not finding this problem in them....
      • rsyarcia
        Hair Straightener Tech
        • 711
        Re: MP C3500
        When you print the counter and test pattern do you see any problem?
        Nobody is perfect..
        • sandmanmac
          • 3981
          Re: MP C3500
          I'm thinking you're not actually a tech on copiers period. Is that correct?
          So, I'm not about to go through the "how to's" of entering SP mode, and navigating to the correct SP, but if you have the manual, it's in there.
          Quite simply, you have a registration issue, and "yes" it's a simple adjustment to perform, (but not so simple to explain)
          Either that, or the tray guides are mis-aligned.
          • kannuki2
            • Feb 2012
            • 398
            Re: MP C3500
            I've noticed of the term "printing" from customers also means copying from the ADF. Simply you have a dust or white out sitting on your small glass on the left hand side.
            • signguys
              Re: MP C3500
              Ya White Out this... Go away OK.... What a joke.
              • TonerMunkeh
                Professional Moron
                • 3865
                Re: MP C3500
                Can you scan and post an example?
                Hit it.
                • lganaden
                  • Jan 2013
                  • 10
                  Re: MP C3500
                  Go to SP mode and adjust the lead edge or side to side registration..............
                  • signguys
                    Re: MP C3500
                    Here you go... Thanks
                    • sandmanmac
                      • 3981
                      Re: MP C3500
                      PDF file would have been more appropriate, but it is now confirmed that you have a slight registration adjustment to be made in SP mode
