duplex printing
  • lukeh
    • Jun 2012
    • 43
    duplex printing
    Does anyone Know how to stop Ricoh M/C's printing a document duplex and the second Page is blank in the document. it increase the meter click by 2 is there away of stoping this
  • sandmanmac
    • 3981
    Re: duplex printing
    Can you clarify this please?
    For example, are you saying that even if you have a single page document, when you go to print it, it duplexes ?
    If that's the case, someone has set that in the printer preferences.
    Go to "devices and printers", or "printers and faxes" (depending on your OS), and go to the printer's properties, under 'preferences' you need to set duplex to "Off" or "No". Then 'Apply'.
    • rsyarcia
      Hair Straightener Tech
      • 711
      Re: duplex printing
      And what specific model?
      Nobody is perfect..
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Re: duplex printing
        Also, go to Advanced tab -> Printing Defaults -> And do the exact same changes here. (Again, depending on your OS).
        • kyrenecopy
          • Apr 2012
          • 205
          Re: duplex printing
          Or, auto duplex could be turned on (defaulted) on the copier itself if it is happening when they copy
          Testing 1-2-3, testing, testing. Is this thing on?
