MPC 305 SPF SC 878-01 please help!!!!
  • Technico
    • Feb 2013
    • 9
    [Error Code] MPC 305 SPF SC 878-01 please help!!!!
    Have Sc 878 -01 code(USB flash error) on MPC 305 SPF.Will not let me do anything ,cant do firmware,just " please wait "forever and throws a code after couple of minutes .Machine is almost new ,like 3k copies .Hard to believe controller board is defective but that's my next step . Any help is appreciated.... Thanks
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 305 SPF SC 878-01 please help!!!!
    What caused the error? Did you perform a firmware update? Or has the error just appeared out of nowhere?
    • Technico
      • Feb 2013
      • 9
      Originally posted by ruben
      what caused the error? Did you perform a firmware update? Or has the error just appeared out of nowhere?
      came out of nowhere.will not let me do firmware update or anything .
      • Polarbear
        • Feb 2012
        • 1070
        According to Ricoh Knowledgebase:
        USB Flash Error
        File system in the USB flash device is defective.
        • Cannot mount partition 3 in the USB flash device.
        • Encryption key does not exist.
        • Cannot find the file for KMMD to be operated.
        1. Replace the controller board.
        I am getting worried seeing the short time between first time install and failures on electronic boards on the current range of Ricoh MFPs! I have had an MPC300 die on setup (new controller was ordered to repair it!), MP2352 controller died 15 days after install at customer.... the list is growing!
        Another franchise had a MP301 controller die when they installed the HDD option! What next??
        Press the GREEN button!!
        • Technico
          • Feb 2013
          • 9
          It is fixed!Replaced controller board,update newest firmware,time will tell.....
          • cbr600
            • Jun 2010
            • 71
            So it didn't worked with firmware update ? what exactly did u replace ?
            • Llama God
              • Mar 2009
              • 1353
              The controller board, at a guess. Well, it's not really a guess as such, he said that it was the controller board.
              Personally I've had no board faults on any of the latest models.
              • Technico
                • Feb 2013
                • 9
                so it didn't worked with firmware update ? What exactly did u replace ?
                controller board and update newest firmware after that .so far so good .....
                • Technico
                  • Feb 2013
                  • 9
                  Originally posted by llama god
                  the controller board, at a guess. Well, it's not really a guess as such, he said that it was the controller board.
                  Personally i've had no board faults on any of the latest models.
                  controller board ,update newest firmware ,that's it...
                  • ucinn
                    • Jun 2009
                    • 383
                    USB Flash Error
                    I've had to replace a couple Lanier LD130C controller boards already. Seems the quality is decreasing. That's what I always liked best about ricohs were their boards were solid. Doesn't seem to be as much anymore.
                    • cbr600
                      • Jun 2010
                      • 71
                      Thx, i have same problem i tried with firmware but it doesn't work.I had a problem before with the lcd and it need to be replaced and now the board, the machine really sux alot.
