LD050 has had issues for some time and started blowing toner all over near developer assembly/PCU and transfer belt. I have cleaned and cleaned, and returned to clean again after user attempted to use the copier while the toner bottle had a hole in it. Now...the issues are as follows and I am at a loss.
Issue 1, despite new web cleaning roll/feeler and sp reset and then new web cleaning assembly is still saying cleaning web needs replacement. Sensor that was shipped did not match part in unit. Right now, the web feeler on the replacement unit is broken off. I have reset SP multiple times and it doesn't clear. The web cleaning roll in the old assembly did appear to be functional. It was advancing.
Issue 2, the unit consistently jams with a J019 error, right after the paper exits the registration roller. It folds into an accordion and doesn't make it to the drum. It does this every time and was jammed when I got to the site the first time w/sc350. I have cleaned the guts multiple times and it still keeps jamming. I have only been able to find one reference to the jam code using google and that pointed to the duplex sensor....
Issue 3, there is still toner leaking onto the blue tab that is used to rotate the registration roller in the event of a jam. It is where the blue tab is and where the transfer unit assembly fits into the right side when the door is closed. The developer assembly is new and still clean, so the toner must be coming from somewhere else.
The waste toner bottle is full...so I know I will need to order that.
Prior to these issues, the copier was producing copies that were consistently lighter as you made them. I have previously rebuilt fuser, replaced developer and PCU, registration roller, toner cartridge holder, transfer belt.. after last cleaning I put in new PCU and developer assembly plus new web cleaning assembly.
