Aficio 1055 with sc300...can aficio 551or 700 drum assembly be swapped for 1055?
  • axyun
    • Aug 2007
    • 1323
    Can I use a 551/700 drum assembly or corona assembly in an aficio 1055 that is giving me sc300? A friend of mine said he thought he did that once and got an sc301 on a good 700 drum assembly when he put it in an aficio 1055. Please advise. Your help is very much appreciated. Frank/ActionPhotocopy
  • ccchuah
    • Mar 2009
    • 153
    Re: Aficio 1055 with sc300...can aficio 551or 700 drum assembly be swapped for 1055?
    the charge corona assembly of 551 can be use on aficio 1055 that caused the SC300.
    • axyun
      • Aug 2007
      • 1323
      Thank you ccchuah. I understand that the corona wire is different in the 1055 from the 551/700 according to parts manual. Frank
      • tjvincent
        • 280
        The corona unit is the same even though it says the wire is a different part number, we use #AD020053 (wire) in both models, the entire PCU is different
        • axyun
          • Aug 2007
          • 1323
          Thank you TJ. Frank
          • axyun
            • Aug 2007
            • 1323
            Replaced corona un it and machine is okay. Thank you for the advice. Frank
