mpc2500 - noisy fusing unit
  • daveh12
    • Jul 2012
    • 157
    [Misc] mpc2500 - noisy fusing unit
    Hi
    I have a mpc2500 and there is a lot of clicking and kind of knocking sounds coming from the fuser. Just can't quite pinpoint the part of the fuser causing it, gears look okay etc has anyone ever seen this before?
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Re: mpc2500 - noisy fusing unit
    You need to grease them up with High heat grease when rebuilding them. Smear some grease where the bearings go and all will be tranquil again....
    • Imprestik
      • Aug 2012
      • 296
      Yeah, your bearings on the pressure roller, heat roller and hot roller are all shot, replace them
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        I agree that the bearings are shot. But when the bearings are gone, belt, rollers etc... are also gone. Best way to change the fusing-maintanance parts.
        Greetings...
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • copyaction
            • Oct 2007
            • 985
            that's it
            • okirob
              • Feb 2012
              • 26
              There is also a gear that can cause noise as well part number is AB01 3722, we usually replace the gear along with all the bearing when we rebuild the fuser
