3035 touch panel
  • Jomama46
    • 2900
    3035 touch panel
    I have a 3035 that needs a touch panel, the number was changed to B213-5225. I also see that it is used on other machines, the 3025 for instance. But on that one there is a bulletin about also replacing the LCDC board if it is an old type. Problem is I dont see that for the 3035. I wonder if it applies to the 3035 and I am missing a bulletin or if it isnt necessary.
    Anybody have any new information on this?
    sigpic
    A+; Network +; PDI+
  • ccchuah
    • Mar 2009
    • 157
    Re: 3035 touch panel
    You can use the 1045 or 1027 touch panel for replacement.
    • Iowatech
      Not a service manager
      • 3930
      For the AF3035, according to the Tech pub list I'm looking at, the touch pad replacement part number is H3109900. For giggles, you might also check out part number H3106173, but I'm not sure about that.
      Then again, this is from at least three or four years ago. Sorry about that if it doesn't work.
