MP C3500 pattern cleaning problem
  • genco
    • 26
    can anyone tell me what the pattern is at the bottom of this print out, and why it did not clean? see attached
  • coolbeer
    • Jul 2011
    • 100
    Re: MP C3500 pattern cleaning problem
    Looks like transfer cleaning unit not working properly or over life.
    • Bantams
      • Jun 2012
      • 603
      +1 poor ITB cleaning
      • Debs1964
        • Oct 2010
        • 1690
        Yep, agreed, ITB cleaning unit required, that is one of the set up patterns that you're seeing. It puts patterns on the ITB to check image density and colour registration
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • genco
          • 26
          my thoughts also except all other prints are fine. seems like printer not cleaning after music pattern although turning off music did not remedy.
          • Eric1968
            • 2458
            Turning MUSIC off isn't a good idea. You'll get registration errors. Just replace the ITB Cleaning Unit.
            • genco
              • 26
              thanks, but cleaning unit was changed. its just a blade, either works or doesn't. anyone have access to firmware update for this machine?
              • Eric1968
                • 2458
                This hasn't got anything to do with firmware, it's simply a worn out cleaning unit. The cleaning unit isn't only a blade, there's also a brush roller. If you replace the whole cleaning unit by a new one, I'm sure this problem is solved.
                • Debs1964
                  • Oct 2010
                  • 1690
                  Yes thank you
                  • genco
                    • 26
                    yes, you have access to latest firmware?
                    • sandmanmac
                      • 3979
                      Yes, I'm Positive that "SHE" does.
                      • SargeNZ
                        • May 2012
                        • 263
                        This is a common issue. It is not firmware. Replace the cleaning unit. This is like Ricoh training day 1.
                        • CableGuy
                          Impulse Drive Engineer
                          • Oct 2008
                          • 417
                          Here's a pic of a shiny new one in a box.....
                          • genco
                            • 26
                            thanks for your valuable insight Sarge, but as I previously mentioned, I did change it. nice pic cg
