Ricoh aficio c3260
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Error Code] Ricoh aficio c3260
    The touch screen display (can not connect to server for remote diagnostics)
    As you help as soon as THANK YOU.
  • sandmanmac
    • 3983
    Re: Ricoh aficio c3260
    Turn off remote diagnostics. SP5816-001. Set to "0" (off)
    • Llama God
      • Mar 2009
      • 1353
      Or run SP5816-209 - this clears all of the settings including the one above.
      • tjvincent
        • 280
        I think on this model you need to go into memory clear and look for "SCS" clear that, it also resets your timers to the lowest settings and deletes your admin user name, so you need to change those back.
          • Mar 2012
          • 171
          Can I make scan as ordinary with twain driver network
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Llama God
              • Mar 2009
              • 1353
              That doesn't make sense; the SP mode that I suggested clears @Remote settings, it's nothing to do with scanning.
              I suggest taking Paul's extended hand and buy a manual.
