MPC 3502 SC551
  • 23889
    [Error Code] MPC 3502 SC551
    Has anyone seen a machine that has 551 codes early in the morning when it first wakes up? It does not do it every morning but does do it about once a week.
    Utlimately tried changing the fuser and checked the main connector for the fuser, tried Firmeware, setting the machine to wake up at 4am only makes the code show up at 4 instead of 6am.
    Any ideas?
  • HP:guy
    • Feb 2013
    • 279
    Re: MPC 3502 SC551
    What kind of environment are you in?
    Is the office cold in the morning?
    • Iowatech
      Not a service manager
      • 3930
      Re: MPC 3502 SC551
      If the machine has "Always On" enabled in user tools, you might see if that machine can be totally shut off properly at the end of the day. Sometimes "Always On" will cause the fuser to warm up slower than the rest of the machine expects, causing problems. Turning the machine totally off at the end of the day and turning the machine back on at the beginning of the new day will at least take that problem out of the mix.
      • 23889
        Re: MPC 3502 SC551
        I cannot set it to always be on. Customer has conservation protocol which this would violate. The enviroment is good and I have the machine in the office now to test. Still gives codes here also.
        • Iowatech
          • 3930
          Re: MPC 3502 SC551
          That went almost exactly the opposite of what I intended, sorry about that. Still, since you have it in the office, you might try this. Turn the machine completely off at the end of the workday, using the power button on the control panel, then waiting for the flashing light to stop, then turning off the red toggle switch. Then, at the beginning of the new workday, turn the red toggle switch back on and see if the code comes back.
          • collme
            Ricoh tech
            • 221
            Re: MPC 3502 SC551
            With the MPC3502 you can just switch straight off at the main switch by tray 1 as the machine will automatically go into shutdown mode before turning fully off. no need to swith off on the control panel on these newer machines
            • richardjj
              Technician - I.T Support
              • Feb 2010
              • 18
              Re: MPC 3502 SC551
              Related SC code: SC 541
              1. Check that the heating roller thermistor is firmly connected.
              2. Replace the heating roller thermistor.
              I would be replacing the Thermistors.
              • collme
                Ricoh tech
                • 221
                Re: MPC 3502 SC551
                original post informed he had changed the whole fuser unit, think that rules out thermistors.
                • richardjj
                  • Feb 2010
                  • 18
                  Re: MPC 3502 SC551
                  Sorry should have read the post a bit better.
                  That aside, we had the same issue with a customer with a MP5500.
                  Changed everything, still did it.
                  We ended up moving the copier to a different location in the office and the problem disappeared.
                  Finally figured out it was on a different power supply phase. We put it back in the same location and fitted a power supply
                  spike / filter supressor and issue went away. Not really sure what the cause was as the machine had been in place for a long time.
                  We looked at the SC log and the times recored for the SC were like 2-3am in the morning, we could only put it down to someting heavy starting up in the aera at that time and causing a power surge. Had the Power board put a recorder on the outlet, but as usual they found / would not admit to anything. Food for thought. Good luck.
                  • collme
                    Ricoh tech
                    • 221
                    Re: MPC 3502 SC551
                    Now that idea i like :-)
                    • Iowatech
                      • 3930
                      Re: MPC 3502 SC551
                      My bad, sorry,
                      • 23889
                        Re: MPC 3502 SC551
                        Sorry for the late response, I was on vacation last week. As far as the thermistors go. I replaced the whole Fusing Unit. I have clipped the wire ties from the connector all the way to the board and power supply, check connectors. The one thing I have noticed is if I turn the machine on with the fuser out of the machine and then add the fuser it will sometimes give the code but not always. The power and enviroment issues should not be a problem since it is in my office and still does the same thing. Thinking of trying a power supply.
