Ricoh MFP MFD Hard Drive file type
  • Ralph S
    I have been asked because of a RFP to supply the information on what type of file is stored on a Ricoh HDD during Copy, Print, and Scan processes.
    As far as I know, the file format in the Rioch HDD is non standard and that the file formats for the temp files are also propriatary.
    That is why you have to purchase a File Format Converter option if you want to save a file from the DOC Server to your HDD on a PC/MAC. Unless you use SCANNER mode to STORE the file of course, as then it is available a s PDF or TIF format. Or if you are storing your incoming faxes on the HDD.
    I have not found anything on Ricoh's TSRC or the internet searches.
