Lanier 5222...
  • JoshRountree
    • Aug 2025
    [Jamming] Lanier 5222...
    I've got a couple of quick questions.
    We have a Lanier 5222 that was jamming continuously so we quit using it. Now we're moving offices and I'm wondering if it's worth saving? Also, does this thing have a hard drive in it that I need to be concerned about wiping before I take it to the electronic recycler?
    Thanks for any help, there's lots of smart people at this forum!
  • sandmanmac
    • 3981
    Re: Lanier 5222...
    I wouldn't spend a nickel on that old box, It's very obsolete. While it's impossible to know the cause because we have no idea what type of jamming - it could be anything from a $5 seperation pad to a complete fuser rebuild, in the several hundred $$ range. Regardless of that, I'm sure it's in need of a few things.
    As for the hard drive - if it had the print and/or scan feature, then probably 'yes'. If not, then 'no'
    If you're concerned, remove the back panel and then remove the controller board on the top right (6-8 screws on a bracket). If there's a Hard drive, you'll now see it and be able to remove it easily
    • JoshRountree
      Re: Lanier 5222...
      Fantastic, thank you so much, exactly the info I needed.
      Does anyone want this thing for parts, I think we have about 4 more in the same series. Located in northwestern NC.
      • fshead
        • 2376
        Re: Lanier 5222...
        thats the old ricoh 220..
        as far as is it garbage i think depends on where you are and
        your $$$$ status..
        i have accnts in nyc throw away perfectly good machines
        because they were 3 yrs old..
        i often would take these and clean up and sell the..
        as for jamming if its out of the tray and not making it to drum units
        it might just need a good cleaning..
        you should state where you are located and maybe someone here cld
        wrk wth you..
        a backup copier
        • JoshRountree
          Re: Lanier 5222...
          your $$$$ status..
          wrk wth you..
          a backup copier
          I just filled out my profile, I'm in Boone, NC.
          I'll probably get rid of it unless I hear from someone, we are moving locations and I don't want to take it with us!
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: Lanier 5222...
            Get it on ebay for parts, someone will always want one.
            Hit it.
