Is there a separate counter for print for this model? Also, How to set the copy track for each account if it has this function. Im only familiar with the Minoltas. I have service manual for this model but can'y find it. TIA
Aficio MP2000 counter
Stewart Norris
Re: Aficio MP2000 counter
The account tracking may be a option. -
If the meter reading is displaying developments and not prints you can change this by using Service Mode SP5-045 and change it from 0 (Development) to 1 (Prints).
On the later models if the machine has user access codes you can print them through User Tools -> System Settings -> Administrator Tools -> Display/Print Counter Per User. If it is not on this model, then try the web manager.Comment
Stewart Norris
If you print off the SMC report, around SP8381 it splits all the pages it has done into their respective functions, I think it's C for copier, F for fax, P for printer etc.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
in ricoh for checking current counter there is user tools .to recognize that key 123 is mentioned on top of key ,same key is used for account tracking .press that key ,select system make user authentication ON in administrative tools then seethe menu programme,change,delete user code ,there u can can programme user code.Comment
