SAVIN CLP340D/RICOH SPC820: toner pumps
  • RandyW
    • Jan 2013
    • 213
    is it possible for all 4 toner pumps to be bad?
    when trying to do the 5-804 output check mode for each pump, there is no response. The different clutches make regular noises when in the output check mode.
    I believe at 1 time the person was running aftermarket toners in at least 2 of the toner positions.
    At the moment, it has a ? symbol in the yellow toner.
    The black PCU life is getting low and black is faded sort of grey most of the time.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: SAVIN CLP340D/RICOH SPC820: toner pumps
    Yes it's possible, especially if they ran aftermarket toner. However not likely that all four failed at the same time. Aftermarket toner in Ricoh color boxes is a really bad idea!!!!!!!!!!!!!!!!!!!!!!!!! The ? for yellow,the machine doesn't know if the toner was ricoh or independant supplier or it can't read the volume of toner in the cartridge.
    Mystic Crystal Revelations
