Need to know Ricoh's Telnet SMTP command
  • uelmo
    Hi ,
    We have 50+ ricoh that needs to change its configuration. I written a script that telnet into Ricoh and changes the DNS. I need to also change its SMTP server address. I google and read ricoh admin manual but i could not find the ricoh command to change the SMTP address from Telnet. If it can not be done by telnet , is their another faster way to change richo SMTP without using web admin panel.
  • Stewart Norris
    Re: Need to know Ricoh's Telnet SMTP command
    Have you printed the configuiration image? The settings are under (user tools ) , (system settings) then (interface settings). Location is on the left side of the control panel at the top.
