Ricoh MP C2500 POSTSCRIPT
  • m_donakov
    • 213
    Hi all i have two Ricoh MPC 2500 one is with PostScript SD card, normal that machine that have postscript installed have better print quality. So if anybody knows if it possible to copy files from postscript to normal SD card so to work like post script or if i could download post script files from somewhere and with some tool to make postscript SD card
    Regards
    Mile
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MP C2500 POSTSCRIPT
    No, you have to buy another PS3 kit.
    • Eric1968
      • 2458
      If you place a PS-Card in a machine, the machine will bind the card to that machine. It's not possible to use it in another machine.
      • sandmanmac
        • 3983
        Sure you can. I've swapped loads of PS cards on this series and others
        • akewldewd
          • Dec 2012
          • 83
          I have too.
          • Jomama46
            • 2900
            The only time you can't is if other software has been merged onto the PS card. Even then if you have the same sn I think you can unmove it
            sigpic
            A+; Network +; PDI+
