MPC3500 code sc549
+ More Options
Posts
  • copyaction
    • Oct 2007
    • 991
    MPC3500 code sc549
    Replaced both thermistors reset ran 2 copies code came right back.
    Anything else common on these for sc549?
  • jam-o-matic
    • Oct 2012
    • 72
    Re: MPC3500 code sc549
    rotation sensor gets knocked out of position after customer removes a jam - located inside machine (remove fuser) on operator side, basically look at the pulse disk on the op side of the fuser & match where it goes into the machine. I just had one of these last Friday & it was knocked out. There is also a TSB for sensor update.
    • TonerMunkeh
      Professional Moron
      • 3865
      Yeah, the sensors can be a bitch. Could also be the ferrite roller is on it's way out or the orange sponge roller has started to disintegrate and is stalling the fuser drive. How many has it done?
      Hit it.
      • copyaction
        • Oct 2007
        • 991
        total count is 170,000
        • spaceman99
          • Jul 2009
          • 174
          thermal pile broken that sits above the fuser. Bit of a tricky job and a major strip down. Wise to always try the thermistors 1st , check contd: of the rollers.
          if you can swap the complete fuser .
          good luck
          • collme
            Ricoh tech
            • 221
            good luck
            SC549 is nothing to do with temperature or thermopile, it is fuser rotation. i second the sensors and sponge roller comment,also there was a tech bullitin for new type sensors, wider gap, also firmware update for sc549. also fuser bearings have been known to dry out and slow fuser drive on this model so always replace bearings with the rollers. ferrite core starts to get alot of play in it to as it ages and as previous comment mentioned, this should be checked as well.
            • copyaction
              • Oct 2007
              • 991
              Went back, sensors not knocked out of position.
              Cleaned position sensors.
              Fuser rollers turning very freely.
              next step try another fuser?
              • collme
                Ricoh tech
                • 221
                Check firmware versions as well, there is a previous update to the firmware for this problem although it has been updated again since for the J001 issue. i would fit a fuser pm kit as it has everything needed in there, unless you were fitting a printer version fuser and not over paying for it
                • FMC
                  • Aug 2008
                  • 88
                  Do the mod on the rotation sensor, you replace the 2 photo sensors (I think it's 2) and replace the half moon shaped bit on the fuser unit that goes through them. Caused me no end of bother at a customer ages ago that had everything else up to date ie firmware and new fuser unit.
