Ricoh 3228c dark color copies
  • jethro tull
    • Jul 2008
    • 54
    Hi to everyone,
    I have a problem with my copier.When i print or make a copy (color) the colors on the document are not right.
    They are too dark.(dark brown,dark red,etc...)I've made color calibration and still nothing.
    The drum units are in good condition.
    Any suggestions?
  • fshead
    • 2376
    Re: Ricoh 3228c dark color copies
    you are not really giving us any info..are the copies streaking,is there a lot of toner around drum and dev units/
    did you ck your count for drums,dev units?
    you canswap between drum units to see if it changes
    • oswaldo160
      • Oct 2008
      • 69
      Change the voltages in SP 2. Drums. And DEV Bias.
      Change in the driver to "economy mode"
      • jethro tull
        • Jul 2008
        • 54
        How can i do that?
        Can you give me instructions?
        And for the records,i 've changed drums,developers,transfer belt unit and fuser unit from another copier(ricoh 3228) that it works fine.
        • oswaldo160
          • Oct 2008
          • 69
          Originally posted by jethro tull
          How can i do that?
          You need to be technician about RICOH,
          In the mode SP -> Clear/modes+1+0+7+Clear/stop
          Type SP 2 Drum.
          • jethro tull
            • Jul 2008
            • 54
            Type SP 2 Drum.
            I've entered the sp mode and now i see copy sp print sp and scanner sp.
            What can i do next?
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • jethro tull
                • Jul 2008
                • 54
                Ok.
                The problem is(after a closer look) that it prints green in differents areas of photograph.
                I've printed each color separately cmyk and the colors are printed good.
                But there is a litlle green in there.
                I think the copier prints more yellow and cyan than it really needs.
                Any suggestions?
                • jethro tull
                  • Jul 2008
                  • 54
                  Ok.This is what it looks like when i print.
                  Can someone help me please?
                  Thanks in advance.
                  • Eric1968
                    • 2458
                    This can be anything. Bad drums, development units (Drums en DV-units last for 60k), dirty polygon mirror motor, dirty mirrors in the laser unit, dirty laser shielding glasses, or even a bad printer driver.
                    • Drummer
                      • Feb 2013
                      • 46
                      Ive seen similar results as this when a customer forces the front door shut when the transfer lever is flipped to the left (breaking or bending the tab on the front door that is supposed to prevent the door from shutting with lever in wrong position).
                      Have you made single color copies of a test chart to see if each color has good fill? Try the black also, as I suspect it is the tranfer lever.
                      Changing the dv bias voltage etc. will not affect copies unless process controll is turned off, however it is probably not the best choice to go tweaking these without knowing the root problem.
                      • CableGuy
                        Impulse Drive Engineer
                        • Oct 2008
                        • 417
                        OEM toner?
                        • jethro tull
                          • Jul 2008
                          • 54
                          Hi sorry for the delay.
                          This is an image i've printed.As you can see the colors are ok except black.
                          • jethro tull
                            • Jul 2008
                            • 54
                            Originally posted by CableGuy
                            OEM toner?
                            Yes.oem toner.
                            • jethro tull
                              • Jul 2008
                              • 54
